I am having trouble with my dash/canbus turning off while driving. The problem occurs when the RPMs are above 4300. When I am above 4300 RPMs:
Every once in a great while I get an over voltage error on the ABS ECU, read from GS911.
I have aftermarket LED headlights and parking lights, but problem existed before the LED headlights were installed.
What I have done so far:
What I believe to be happening is the dash/canbus gets an over voltage. The stator puts out full power around 5,000 RPMs. When I first start out on a drive I don’t get the problem until the battery gets to full charge, approx 5 min. (Also usually driving slowly out of a residential neighborhood) I think when the stator is at full power and the battery is full, the dash/canbus is not seeing the correct voltage. I cannot figure out where the problem is being generated. The voltage at the battery when metered on a multimeter and in the GS911 show the appropriate voltage but have not found a good way to drive around and log the voltage yet. (Looking into a logging multimeter) I am not the first owner, some mods have been done but I have disabled almost all the electrical mods and none are on the dash/canbus except LED headlights.
I am up for ideas as to what I should check or test next. Thanks in advance for any wisdom anyone can share.
- Tach will drop to zero
- Shift light will come on
- The milage displayed will switch with lap times
- The gas light will turn on
- The headlights will go out
- The taillight will go out
- Tried a second voltage regulator
- Did the aux power cable mod on the regulator
- Bike came with a Shorai lithium battery and have swapped with an AGM for testing. Same problem on both batteries.
- Checked much of the wiring harness for obvious crimps and abrasion.
- Reseated wiring harness connectors on the canbus devices and ECUs
