K67 Battery Replacement
9.6K views 13 replies 6 participants last post by  paxman
#1 ·
Hi,
I'm building a track bike based on a 2022 K67 none M model.
So I'll have to replace the heavy battery. Any of you have track bikes with after market batteries ?
Thank you
#9 ·
@BMW_388 There must be a vendor making a k67 specific one ? or did they all give up as the M model is so prevalent ?
Just an idea : Who makes the M battery ? I assume BMW sells it for 500$ when you can directly get it for about 250$ ?
#11 ·
#12 ·
earthx battery. cell balancing built in.
Cell balancing is a product of a BMS device. Battery Management System is how a LiFePO4 survives many cycles of charge and discharge.
Most of these batteries are based on 3.2V cells in the 80AH range. So we stack 4 @ 3.2VDC in series making a 12.8VDC @ 80Ah up to 200Ah. The BMS handles the charge cycle and the alternator is special in the S1000RR that is factory equipped with the M Battery package.
