Here's an easy to follow video for anyone planning their first trip trailering a bike on how to keep it from getting damaged in transit even with no help.
I have done 5h trip, bike only on rear stand, no problemo. "Ooops..."A "friend" one time loaded his bike in a Condor chock in an enclosed trailer and got distracted, forgetting to tie it down further. The trip was short - roughly 1/2 hour - but the bike was just fine without any tie downs!
appreciate added details:Some good tips, few things I would change:
- Use the triple to strap the front to avoid putting any load on grips/electronics. It's what BMW recommends in manual.
- I would add to keep it in 2nd gear to avoid bike rolling. Reduces longitudinal stress on straps.
- I would use the subframe/pegs instead of swingarm for rear strap, you would want the support as high as possible to reduce lateral load on front and keep bike secure under abrupt maneuvers.
Or, to be exact, it can move to any direction a little bit, but not so much that it could cause straps to get loose.You really want the bike anyway to be so well secured there is no motion forward or backwards.
I can't imagine any load being put on the transmission gearset by putting it in a wheel chock that is anywhere near to or equal to the stress put on it by RIDING it. Also, if you can get it into gear while in the chock, that most likely means that you did it because of the current slack in the chain and gearset (otherwise it'd be way more difficult) and the bike would have to move a certain amount (taking up the slack in the chain/gearset) before putting any load from any fore/aft movement into the gearset anyways. Which the straps should prevent. I put mine in gear just so that if I take the straps off after arriving, that the bike can't just roll backwards out of the chock. My chock has a part at the back that prevents this anyways, but it's an old habit and can't hurt anything, so why not?Ok, let's not get theoretical.
With TRS or straps, should bike be in N or gear during transport?
Oh man, I wouldn't even TRY and load that in the minivan. First of, it'll be a TOTAL b!tch just getting it in and out. Second, you don't know if the floor of the minivan will support all that weight per square inch considering that the 420lbs or so will ONLY be concentrated into 2 small contact patches. When they give a load rating for things like minivans, they consider that the load will be evenly distributed, which this isn't. For those trips where you want to bring the bike, I'd suggest just renting a U-Haul for the weekend or whatever.When I initially purchased my bike I hauled it from Detroit to Ohio.. and used Rhino motorcycle straps from Amazon and U-haul. I was quite concerned as this was the first time hauling a trailer and to top it a brand new bike but it had to be done. For the front I used the forks to get it strapped and back I utilized the peg, it was very stable as I frequently made stops to check the straps. Some pictures of it below.
With that said I need input/tips best way to secure the bike in a mini van-
so this morning I went to harbor freight and got the ramps.. been wanting to try this for a while and finally did it. The height of the bike sits at 40-41” without windscreen and the odyssey trunk opening sits at 42”. So I knew it’s gonna be a close fit.With the help of-the mailman and the wife was able to successfully get it loaded and unloaded. It’s definitely at least 2 person job with 3 being best. I’m planning of using Maxhall wheel choke to stabilize the bike inside and then strap it down. Has anyone-tried doing this in a mini van if so did you guys face any issue with it? The only downside IMO is it needs two person to get it on and off.. didn’t drive with it so cannot speak on the stability. Had my hands full so couldn’t get picture with the bike inside… but there is at least 1-2” room height wise once it’s inside.
Reason for using a mini van cuz it’s all I got lol.. I work from home and when I go to work I use Honda Civic coupe.. the wife’s car is an Outback but does not have a hitch.. even if I get a hitch installed she would need that car for the kids.. currently not thinking of buying a truck just so I can haul my bike around.
View attachment 218000 View attachment 218001
