1 - 13 of 13 Posts
hello guys
i need help here i bought a 2011 BMW s1000rr with 3300 miles on it i had a chance to take it to track one full day and have fun with on race and sport mode with no issues at all
no bike has a slipon akrapovic exhaust with danmoto v pipe and OEM heathers custom done to fit the bike as i have seen on my BMW with the same set up
2 days ago i did a track day my first lap of the day VDS error came on on turn 5 and killed my bike i saved it some how some way
as i exited it the track i turn the bike ON it started with no issues then i decided to ride again but in mined i was already going to call it end of session as i am riding turn 12 bike died again with the same error VDS icon showing on my dash
does anyone know whats going on whats happening
this is my first BMW ever i am a ducati guy and i never had issues after 10 years on DUC's bikes
need help here
thank you
Check that the drop sensor has not come free of its mounting and may therefore be giving you the problem. VDS errors are drop sensor thinking that the bike is on its side and killing the ignition
Sent from Motorcycle.com App
hello guys
this is my first BMW ever i am a ducati guy and i never had issues after 1 years on DUC's bikes
need help here
thank you
My '11 did the same thing except I was on the street. I ended up just unplugging it. It will run just fine, but shows VDS error. I haven't had the chance to get it to the dealer, but I believe the sensor is the problem.
^^+1 on what John says. The VDS is a vertical drop sensor located under the seat across from the sock plug. If it's come out of it's harness or mount, the bike thinks it's been down. Here's a thread with good info in he last post:
http://www.s1000rrforum.com/forum/bmw-s1000rr-general-discussion/8938-vds-code.html
Good luck
found somthing
do you guys think this was the problem
found the sensor off from its unit and i put it back but i have no clue if this will answer the question
i will ride the bike around keep you all posted
thank you all for helping out
well looks like i found the problem and fixed it
took the bike around about 2 miles riding around the streets near by my bike didn't die nor error appeared on the dash i was all worried it will die again and i have to push it to my my garage lol
problem salved so happy
thank you all
Let me throw this out there.
Mine has been yelling a service reminder at me since the first of the month (I changed oil back in March and didn't update the reminder). So this evening I got out my GS-911 to reset the reminder and found that mine showed a Vehicle drop sensor fault code plus it also showed that I had disconnected it.
Popped the seat and installed my old VDS and dash went out showing VDS. Reset the fault code and the dash cleared. Bike started right up no issues.
Have no clue why clearing the code made things o.k. , but so far it did.
Yep, you got it. As the other posts say Zip tie that thing down next time you're under there. It seems to like to hop out if you're working around it.
Hey all,
I've been having a similar issue with my 13 s1000rr. I was riding around 25mph I then notice my speed went to zero, then traction control light lit up and got the vds code. After a few seconds the bike turn off and didnt want to crank. It sounded like the battery was dead. After a few days I charged the battery it started right up.
Hey all,
If the battery is low or the terminals were loose then you can get that VDS error and symptoms you describe.
1 - 13 of 13 Posts
