1 - 16 of 16 Posts
Other thread got too cluttered. Making an updated thread here of the remaining parts I have laying around:
Hp4 engine $2500(I have the entire kit to make your 2010-2014 s1000rr an Hp4).
2010 S1000RR frame with clean GA title showing 4K mileage on the title $2500
2014 hp4 cluster, Ecu, key/ignition, tank lock $1500. The cluster and Ecu was sent out to Alpha SBK in Germany for them to install RCK2 software onto the Ecu and to remove the ddc error message on the cluster because the bike was using Ohlins suspension. I paid $2000 for this flash.
hp4 upper triple clamp #5679 $400
hp4 rear brake caliper $75
hp4 gas tank with fuel pump $250. Tank has normal wear and tear and a super small tiny dent. Can’t find it unless you are really looking for it.
hp4 front calipers $400
Armourbodies fairings professionally painted teal. Never crashed or repaired $500
Woodcraft clip Ons with OEM hp4 switches $350
oem bmw fairing stay $150
hp4 wiring harness complete $350
2010/2011 s1000rr wiring harness complete $250
oem carbon fiber muffler bracket $75
2010-2014 s1000rr/hp4 radiator $400
Brembo clutch lever $75
2018 s1000rr swingarm $150
hp4 swingarm $150
Oem hp4 front tire hugger fender $100
Cox radiator and oil cooler guards $75
oem s1000rr front brake calipers with pads $150
oem bmw s1000rr rider seat $100
anything else, ask. I may have it.Text/call 727-678-8904 anytime as I am not too active on this forum. Thanks.
Hp4 calipers sold
Both sets of Cox radiator guards sold
Don’t be cheap. Get yourself some badass parts before they’re all gone.
Do you have a hp4 sprocket hub ? for a 2011 if it matters
If you have cast wheels you need a sprocket carrier for cast wheel. If you have HP wheels then you need a sprocket carrier for the HP wheel. They are different. I do not have any.
Oem rider seat sold
Oem s1000rr front calipers sold
remaining items:
Hp4 engine
Hp4 cluster
Hp4 Ecu
Hp4 key/ignition tank lock
Hp4 upper triple clamp number 5679
Hp4 gas tank with fuel pump
Hp4 full wiring harness
Hp4 oem switches with woodcraft clip Ons
Hp4 swingarm
Hp4 radiator
Brembo clutch lever
2010/2011 s1000rr full harness
2018 s1000rr black swingarm
2010 s1000rr clean title frame
Discussion Starter #10
Hp4 engine sold
Hp4 cluster sold
Hp4 Ecu sold
Hp4 full wiring harness sold
Hp4 key, ignition, tank lock sold
Hp4 switches withwoodcraft clip Ons sold
Hp4 upper triple clamp sold
Discussion Starter #12
Last cox radiator and oil cooler guard set sold
remaining list:
2010 s1000rr frame clean title
Brembo clutch lever(2010-2014)
2010/2011 s1000rr full wiring harness
Hp4 radiator
Hp4 swingarm
Armourbodies race fairings professionally painted teal never crashed
Hp4 front brake lines(bigger diameter than s1000rr)
Need to move this ****
Discussion Starter #15
Hp4 front brake lines sold
Hp4 carbon fiber mid pipe piece sold
Brembo clutch lever sold
Oem rider seat sold
remaining items:
Hp4 engine
Hp4 cluster
Hp4 Ecu
Hp4 swingarm
Hp4 radiator
Brembo clutch lever
How much 4 the cluster
1 - 16 of 16 Posts
