Got robbed twice is allGot inspired by Home Alone![]()
That hurts lol Sorry buddyGot robbed twice is all
You need an XR with panniers and the larger top box to fit a whole hooker, and only a small thin one at that. The coin box area will fit a few fingers.I stuffed a whole hookers hand there once.
Only a small, thin one? Sounds like you're just not trying hard enough.You need an XR with panniers and the larger top box to fit a whole hooker, and only a small thin one at that. The coin box area will fit a few fingers.
You're right, but you don't have much air gap room left over. I did the calcs and you can get a 130 lb hooker in there. The panniers are each 31 liters and the top box 28. The 130 lb hooker can be mushed into 60 liters if you squeeze out all the air. You will clearly need to use plastic bags to keep it all from oozing out. And don't try to fit a really big girl.Only a small, thin one? Sounds like you're just not trying hard enough.
Could not hurt to watch a few seasons of Dexter for some better ideas how to properly dispose of a body. We can all agree the RR model is not a good candidate, unless you are just trying to evade the police then yes its the perfect bike.You're right, but you don't have much air gap room left over. I did the calcs and you can get a 130 lb hooker in there. The panniers are each 31 liters and the top box 28. The 130 lb hooker can be mushed into 60 liters if you squeeze out all the air. You will clearly need to use plastic bags to keep it all from oozing out. And don't try to fit a really big girl.
You are removing internal organs, right?You're right, but you don't have much air gap room left over. I did the calcs and you can get a 130 lb hooker in there. The panniers are each 31 liters and the top box 28. The 130 lb hooker can be mushed into 60 liters if you squeeze out all the air. You will clearly need to use plastic bags to keep it all from oozing out. And don't try to fit a really big girl.
Into the tank bag?You are removing internal organs, right?
In yer belly!Into the tank bag?
