1 - 1 of 1 Posts
Light, durable and comfortable. RT-RACE Pro boots from TCX are top-of-the-line boots that’ll hold your feet safely in place no matter how you ride.
It starts with a laser-cut, perforated microfiber outer shell that’s armored in all of the right places: the toes, lateral/medial malleolus, heel, shin and Achilles. Still, comfort is more than look after. Ventilation aside, the aforementioned protectors work together allowing a natural, comfortable foot movement that’s unobtrusive whenever you’re on the bike.
Additionally, replaceable magnesium toe sliders are fitted as standard, and there’s also a set of replaceable heel sliders fitted on the back of each boot. A polyurethane shift pad is correctly positioned to eliminate abrasion caused by some of the rougher footpeg serrations found on some aftermarket rearsets.
Inside the boot, an Air Tech breathable lining is fitted as standard. And once your foot is within the boot, you are to cinch it in place using the integrated Fasten Fit Control (F.F.C.) lacing system. It’s just as you’d expect, an internal lacing system with its own locking system to hold your foot comfortably in place.
Michelin is the company responsible for the boot’s sole – in this case, the Burnout compound which is designed to provide sure grip in all riding conditions. In addition to predictable traction that doesn’t inhibit feel through the pegs, you get a durable sole that’s highly resistant to tearing and abrasion.
It all adds up to a nifty, protective boot that’ll keep your feet comfortable at the track or out on the road.
To order yours, call us on 866.931.6644, send a note to TJ via email; [email protected] with TCX RT-RACE PRO AIR BOOTS in the subject line or just send a PM right here along with the size of your regular shoes you wear and we’ll get back to you right away!
1 - 1 of 1 Posts
