1 - 7 of 7 Posts
Spark Slip-on System with Moto-GP Muffler Electro-Black for the S1000RR/R (09-14)
Spark Moto-GP™ Slip-On Key Features:
Spark Moto-GP™ Electro-Black systems are manufactured using the finest quality stainless steel and then chemical coloring is prepared, using a mixture of chromic and sulphuric acids that develop the thickness of the naturally occurring passive film, on the steel surface. The colors that are produced are the result of light wave interference, as light is reflected from the surface of the thickened oxide passive layer and the interface of the passive layer and steel surface. The colors seen depend on the thickness of the oxide layer formed in this process. Unlike anodizing, as used widely on aluminum products, the process is not an electrochemical one and in contrast to painting, there are no pigments or coloring chemicals used. Perhaps more important, the process does not rely on heat to oxidize the surface. Chemically colored stainless steel retains the aqueous (atmospheric) corrosion resistance of the un-colored surface making the electro-colored system a great option for riders in harsh environments and ocean areas.
Advantages of the Electro-Black Spark Moto-GP™ Muffler:
  • Better scratch resistance that the basic 304 grade stainless
  • UV resistant, won’t fade in the sunlight
  • Water and dirt repellent
  • Will maintain its appearance without rusting or discoloration
  • Stainless steel is an environmentally sustainable choice, being it is completely recyclable
Features:
  • Industry exclusive electro-black stainless
  • 8.5" GP style megaphone muffler
  • 2.25" outlet permanent baffle
  • Electro-black finish (chemically colored stainless steel)
  • Rich, race-inspired sound
  • Stainless steel heat shield included
  • An easy and affordable way to customize your bike
  • Laser engraved Spark logo
  • Includes muffler, elbow, heat shield and necessary hardware
  • Designed to work with OEM front section only
CLICK HERE TO LEARN MORE
There is a DB insert that can be purchased for those mufflers. We have an email out to Spark to see if they have DB ratings on the muffler for you.
Here is the list that they sent back to us.
FULL SYSTEM: silencer +TITANIUM collector MotoGP 113 dB at 6000 RPM
FULL SYSTEM: silencer +S.STEEL collector MotoGP 113 dB at 6000 RPM
FULL SYSTEM: silencer +TITANIUM collector Force 104 dB at 6000 RPM
FULL SYSTEM: silencer +S.STEEL collector Force 104 dB at 6000 RPM
FULL SYSTEM:silencer +S.STEEL collector Force 104 dB at 6000 RPM
FULL SYSTEM:silencer l. 350 +TITANIUM collector Force 101 dB at 6000 RPM
FULL SYSTEM:silencer l. 350 +S.STEEL collector Force 101 dB at 6000 RPM
FULL SYSTEM:silencer +TITANIUM collector Konix 107 dB at 6000 RPM
FULL SYSTEM:silencer +S.STEEL collector +TITANIUM connecting pipe Konix 107 dB at 6000 RPM
1 - 7 of 7 Posts
