Hello everybody,
as it is winter (at least here in Germany) I had time to do some changes concerning the ECU of my RR. The adjustement for the mounted Remus exhaust system was not done well until now (much too lean, a/f up to 1/15 around higher revs!) even with the Rapidbike EVO system mounted (comparable system to Power Commander V with AT). The support of the Rapidbike system was awful also and there was no solution for the problem (I even had some awful engine hardware problems in Brno because of that I think
), so I removed the Rapidbike and went to RS2e (ex-AlphaRacing engineer) for flashing the ECU. A new mapping was uploaded (racemapping concerning ignition,a/f ratio,air intake funnel switch time,quick shifter adjustement,traction control etc.).
Now I have the problem that I have a flashed ECU, a cable for the interface but I need the software for the Race Calibration Kit 2 (RCK2):serious:
It seems to be difficult as I searched quite a long time without finding anything....
Can anyone give me a hint where you can buy the software (only the software e.g.as download or disc)? Alpha Racing sells only the full package but I do only need the software.
Thank you very much in advance! Greetings!
Roman
Roman
