1 - 15 of 15 Posts
Hello friends!!! I have a problem with my bmw s1000rr quick shifter. It works when it wants and i dont know why...know someone something? (Model 2015)
Is it plugged in properly???
btw you are probably going to be asked for more details by those that could really a have any insight into this, your diagnosis is extremely vague!
Yes it's from factory plugged in... And this problem is itself vague... It just works when it wants... I dont really know what happend
Make a photo of it mate and attach here. Often the most common problem is that lever to rod angle is not 90
aftermarket clutch lever = bad most likely
looks like your clutch perch is cracked and most likely your whole issue is the actuation of the micro switches not working correctly
Reactions: Gixxerguy855
You think if I replace again the factory clutch lever it will work?
I would at least try it on the lever.. is that perch cracked? It looks like it in the pic .. if the distance to the micro switch is not correct it is not going to work well or not at all.
Discussion Starter #11
I havent this problem before 2-3 weeks...now without reasson do that
good eye!
Discussion Starter #13
Guys the problem isnt the micro swichs or my lever because i did reset to quick shifter and worked normal...and after 2 days didnt work again and i did again reset and d worked...I dont know what's happening... Really
in talking with US BMW race support, apart from troubleshooting the clutch switch, these quickshifter units do fail. It has been recommended as one of the items to have at the race track as a common spare. They run about $200 on eBay
1 - 15 of 15 Posts
