1 - 12 of 12 Posts
BMW S 1000 RR 2016
Evolution Line (Titanium)
S-B10E5-CZT
The flagship of the Akrapovič exhaust system range, used and tested by our top factory teams in motorsport racing. It is simply the finest performance exhaust system available. Each model is unique and dedicated to maximizing the performance of an engine, while reducing overall weight for optimized handling of the whole motorcycle. It is made entirely of titanium.
It’s not just about peak power—Akrapovič exhaust systems deliver increased performance throughout the entire rpm range. Increased power and torque result in a much smoother ride. All Akrapovič exhaust system measurements are made on our computer-controlled chassis dynamometers.
By simply bolting this system on and making zero modifications to the ECU, the performance stats will yield the following:
12.2 hp at 8100rpm
7.4 ft-lbs of torque at 7850rpms
and..
15lbs in weight savings!! 65.4% lighter than the stock system.
And all this is just a start!
Check out the sound bite:
Akrapovi?
Ready for optimal performance enhancement for your S1000RR?
The website says 6.8kg
Ah! It's 65.4% weight savings. Mystery solved.
With the 65lb weight savings and after I add my winglets I shall not only run the streets but I will slice up my competition like a man on a mission.
1 - 12 of 12 Posts
