Hello everyone, so I was riding and I got 3 errors today and would like to ask for some advices over here !
First picture: Lambda sensors are disabled because of Power Commander 5 (So those 2 lamba errors are probably false positive) ?
Also I got exhaust flap error, my system is fully opened so I assume flap is removed and error is displayed because of no flap physically connected (Same situation as for lambda sensors) ?
Second picture: I was looking through all settings and found way to unlock 200miles mode.
After that I've found oil level sensor, oil level low/high option.
I did changed from disabled to enabled on both mentioned options.
After I did applied settings, the option "slope sensor" enabled it'self with option "fall sensor".
My question is, since I don't see anywhere my oil level on dashboard (I enabled those options mainly to see level on dash) can I disable these two options back to off ?
And did I fked up something with this ?
Third picture: I was looking for adaption values for gearbox, didn't reset anything here.
My question is, are those gearbox values okay ?
Many thanks for your time.
