1 - 11 of 11 Posts
Hello. Anyone knows how i can change the kombi rpm limit with e-sys.
I can login with esys but which line is and which value.
I need to change it at instrument not at ecu.bmsx ecu bike 2015.Thanks
I know what he means, he wants to change the presets in the shift light which is defined as 14000 as the top limit. What he wants requires knowing how to edit the CAFD and not within ESYS unless it is defined already by TM.
I don't mean the first 1000km rpm limit.
At setup menu if you select offrpm it goes to 16000rpm.
Where i can change this value with esys at the kombi?
fist rides the ecu limit was 17000rpm and the instruments was showing 17000.
After 50km the rpm limit went down to 16000. It's not the ecu limit but the instruments value offrpm
1 - 11 of 11 Posts
