1 - 10 of 10 Posts
Hello i am going to replace my Abs pressure modulator ,( its not working properly )
I have another ABS pressure modulator from ebay removed same year bike , after installation does it need any coding or somthing ? Or just install break lines and thats it ?
2021 S1000RR M Sport
You will need to bleed the whole system once you install it. This involves purging the pump and you will need a GS911 to do it. You will have a vin mismatch for this control unit but it should not cause any issues. Also if it is a newer RR with ABS pro there is a possibility the ABS coding version will be wrong inside the control unit which will log a fault. Just make sure you bleed it and that your brake lights are working correctly as the brake pressure status is used for mode changes.
Discussion Starter · #3 ·
Thank you very much , i abs pro version , i also have GS911, Esys for coding and Ista + for connection to the bike , just i am thinking how to code it properly
No coding needed. Just plug it in. Use GS911 and brake bleeder to bleed system. Done. Should be no issues. Make sure brake lights work correctly.
i eliminated mine. It went straight in the rubbish container. The lines that go inside the chassis I used industrial cutters.
On K67, but you plugged the ABS pump? Cut lines to pump, went direct to calipers front and rear?
i removed the pump and left the electronics using the alpha racing cover plate. My lines go directly from master to calipers. I've probably have shaved off a sand bag off the bike.
Discussion Starter · #10 ·
I replaced pump , old pump part number was different vs new one but both was S1000rr abs pro pumps ,
After replace pump, abs and cruise control was not working, it was writing 480B2F (coding error) . So i had to used Esys for reprograming and now it works cool
1 - 10 of 10 Posts
