Replacement cover
4K views 11 replies 6 participants last post by  Ladc5
#1 ·
Does anyone know where I can get a right side replacement generator cover? I've checked ebay. Just trying to see where I can get one before I get an aftermarket one. At the bottom of the scuff mark there's a tiny pin size hole that oil slowly leaks out from. Anyone think this could get fixed somehow...maybe have a tig welder possibly fix it? If not, no big deal...I'll just replace it.
#3 ·
Honestly if you want to have it stop from leaking till you get another one, so you can ride till then, I'd use JB Weld it will definitely stop the leak. Also try to invest in a set of covers when you are ready to replace the oem one.
GB Racing BMW S1000RR 09-13 Engine Cover Set from SportbikeTrackGear.com
Yoshimura BMW S1000RR 10-12 Case Saver Kit from SportbikeTrackGear.com
Woodcraft LHS Engine Stator Cover Protector BMW S1000RR 10-12 from SportbikeTrackGear.com
Woodcraft RHS Engine Crankshaft Cover BMW S1000RR 10-12 from SportbikeTrackGear.com
#6 · (Edited)
Hope you guys don't mind me piggy backing off this post. I'm actually in the process of installing some case guards. My question is, what is the proper torque for the bolts that hold these case covers on? According to the manual, it looks like it should be 3 Nm (2.2 foot pounds of torque). Dose that seem low? My torque wrench only goes down to 10 foot pounds. When I set it to as low as it will go and turn one of the manufacture torqued bolts, it will continue to tighten. This was a test on one bolt. Also, do you know of wrenches that will go that low?
Any help will be greatly appreciated.
Sent from Motorcycle.com App
