1 - 14 of 14 Posts
Removing the USA DRL
A major issue for me
with the Gen 2 XR has been the USA Daytime Running Light (DRL). The right two headlights stay on ALL THE TIME.
This is not the case with the European Models. Their Gen 2 XR’s just have the front LED’s running during the day.
A moderator on this BMW RR Forum has solved this issue. He is BEMRR Wizard (Shop | BEMRR Wizard ). Over the course of Saturday night he figured out how to install the European Auto daytime lights (DRL) on my 2021 BMS S1000XR.
After the install by BEMRR you go to the SETTINGS/ VEHICLE/ LIGHTS & turn on the Auto daytime lights (DRL’s). The change one see’s with this install is a small “A inside a light” appears on the left inferior corner of the TFT all the time. In sunlight a green light appears on the left side of the TFT. When the green light is on then, THE RIGHT HEADLIGHTS ARE OFF & the bike only has the front LED’s running during daylight!!! This feature is installed on European Gen 2 XR’s but, not those shipped to the USA.
Yes, I did remove the Bren Stage 1 tune during this install to be safe. Reinstalled the Bren Stage 1 tune and there were no issues.
For all USA owners that want to get rid of those awful DRL’s get in touch with BEMRR Wizard at Log in or sign up to view or [email protected]. You will require:
1. ENET cable- BMW (order off ebay)
2. Windows Laptop with ethernet port. If not then you will also need a USB to ethernet adapter (Not MAC/Apple)
3. Teamviewer software
I have NO FINANCIAL INTEREST in this mod…
Best,
Doco_O (y) o_O
I modified one of my Ducatis with a Euro switch set which allows me to turn off the headlights for starting the bike (the headlight otherwise remained on). One could certainly run the bike without a headlight as well, of course.
I have no idea what KTM does or does not do.
Best,
Doco_O (y) o_O
Gary:
Thanks so much for sharing this. I've already contacted Bemrr Wizard to have this done on my bike. Question...did you DRL's (LED's) become brighter once this was activated? It seems like they run at 50% brightness with the US spec (RH low beam on).
Thank you!
Discussion Starter · #9 ·
Gary:
Thank you!
duress,
Yep, I noticed that also. The mod does make the front LED's brighter to me.
Best,
Doc:unsure:
Best,
Doco_O (y) o_O
Do you know for sure that this is legal in the US? All states require a headlight on at all times, don't they?
Discussion Starter · #11 ·
Xray,
Good question. That is one you are going to have to answer yourself.
I own a KTM GT and the OEM DRL came like this:
Never been stoped in the SE USA with this bike since 2017.
Glad, I no longer have to drive around with a "Popeye" bike.
Best,
Doc :unsure:
1 - 14 of 14 Posts
