100% the 10-14 are only 10-14.. The method of QS linkage is one of the biggest issues.Can somone Direct me to the link or jst let me know what year rear sets can i fit onto my 2014 s1000rr, will the 2015,up to 2018 the 2014 model, THADWADA IN ADVANCE.
MANY THANKS FOR THE INFO, SAVED ALOT OF GRAY HAIRS .The frame changed in 2015, so I do not think the 2015+ rearsets will fit on prior year models(2010-14 and the HP4).
i installed the attack shift lever with more adjustment, was able to rotate the shift arm on the tran down 1 more tooth, and it's shifting pretty good right now. i might still try to fine tune it more as it'll never be perfect with mixed models, but still pretty decent, just not quite perfect for an ocd like me.100% the 10-14 are only 10-14.. The method of QS linkage is one of the biggest issues.
Attack makes some good 10-14 model rearsets. I worked with those on @verrucktaxe build on his 2010 in conversion to 2018 hardware. I did convert his shift linkage to 15-19, but I dont recommend trying it as the rearset attachment is still wrong from the 15-19 on the 10-14.
