anyone using these on their bikes and any issues with bike running hotter etc.?
thanks mateNo issues mate. OEM or aftermarket. They all work.
thanksI would never operate my BMW's without radiator and oil cooler guards. Even BMW decided to OEM some of these products for the K67.
thanks ,im getting themHaven't looked at after market. I have the oem guards. I like that the grid is angled. If you look up from the direction debris would come off the wheel it's virtually impossible for anything to directly hit the radiator and there's a gap behind it that's big enough for anything that could get through to drop down behind the guard.
thanks mate, will make sure mechanics are awareOEM is cheaper too!
Had a friend who had a rock hit his GS radiator and we used JB Weld to get home. Now, I always install them prior to bike delivery.
thanks very much, will make sure mechanics are awareBe aware that the service bulletin calls out for the use of push rivets....BMW calls them clips. If used as is, they'll smash/bend the hell out of the oil cooler fins where they're installed. I chose not to install the clips but instead used rubber bumpers placed on the edge of the oil cooler guard to provide the additional spacing. bennymx said he cut off the head end of the clips to install into his oil cooler. He said it didn't cause any issues with the fins.
If the rubber bumper method I used doesn't pan out, I'll do what bennymx did as I bought the clips. There are five of them which need to be installed. You might want to bring this up to the mechanic if you choose not to install the guards yourself. Also, the service bulletin is only for the oil cooler guard and not the radiator guard.
try R & G , choice of three metals, alum, s/s, and titaniumI think the OEM ones are plastic thats why I never wanted to buy the oem ones I'm looking for a set on mu bike bit hard to find anyone with stock these days
It was the first thing I did when I bought my new bikes. On my RR I got mine in anodized blue. Matches the bike‘s paint. Radiators are expensive.anyone using these on their bikes and any issues with bike running hotter etc.?
