I noticed this issue start to crop up intermittently, now it's almost constant.
Under WOT and nearing redline (anywhere above 12k-ish RPM), the QS refuses to shift from 2nd to 3rd 95% of the time and 3rd to 4th 75% of the time. I did back to back tests to make sure I wasn't lazy shifting. The QS will cut ignition timing (RPMs drop slightly / stop increasing, which also causes me to launch forward over the tank), but the shift will not complete.
Under "typical" riding conditions, such as light to medium throttle or almost WOT but at lower RPM, the QS works flawlessly.
Any insight? I haven't tried a relearn since I don't have access to a GS911. Anyone in the Bay Area (CA) have one that I could use? Will make it worth your while
