1 - 1 of 1 Posts
Your quickshift not working can be caused by a few things. The quickshift may need to be taught in. This requires a reset of the adaptations and then running the bike in neutral for 10 seconds. Then running through each gear for 10 seconds using the clutch to change from 1st all the way to 6th once 10 seconds in each gear has been done. You can do this while riding the bike or with the bike on a rear stand. Once you have gone from 1st to 6th they should be taught in. A reset can be done at the dealer or via a GS911.
Another problem is having a very loose clutch lever free play. On the track mainly at high speed the wind pushes the clutch lever in enough that when you try to use the quickshift it does not work. People always check the clutch switch and find that the tabs are not bent. Please refer to adjusting the clutch free play.
1 - 1 of 1 Posts
