1 - 8 of 8 Posts
its been intermittent for awhile, did the reset and learn a few times with no fix. today I did this
With the
gs911 connected they are working results : Clutch Sw 1 Clutch Sw 2
Normal Not Actv Activated
First Click Not Actv Not Actv
Second Click Actv Not Actv
After I did the transmission Reset and did the running thru the gears procedure the values are
1st .28
2nd .733
3rd 1.204
4th 2.953
5th 3.875
6th 4.736
Resistance check from the Quickshifter cable across the pins I can't notice any changes across any of the pins when i activate the shift lever! Really looks like I have a bad one
what are the symptoms of your issue?
Just refuses to downshift blip or will not upshift smooth at all?
This on a 15/16 ?
what year is the bike? I had the same issue and I was able to fix it with a zip tie. For me it was the small flap that engages the button when the lever is not being used. You'll be able to you tube the video.
10-14 QS issues > Wiring is a major issue for some, then the replacement of the QS itself for others.
Could be ECU programming or ECU hardware issues also. I have cloned and replaced a few 388 ECU , but mostly for the coil drivers and injector drivers going bad in the ECU.
1 - 8 of 8 Posts
