1 - 20 of 27 Posts
Hi,
I'm developing new bar end weights for the post-'19 S1000RR. Would someone be able to remove one of theirs and weigh it for me?
First person who can post an answer here, will get a free pair once I make them.
Thanks,
Steve
HVMP Inc
Discussion Starter · #4 ·
My current design is at about exactly double the weight with the screw included. With a tapered profile, so it should look pretty unobtrusive. Thanks again
Wood Font Gas Rectangle Metal
If you didn’t make a tapered end would it be heavier? (Why of course it would be) I’d be interested in a non tapered set to help with the vibration.
Perhaps weight alone is not the answer, it might be about getting the right weight?
Reactions: Ravenbravo and ZZZ
Discussion Starter · #7 ·
Exactly. We originally used the template for the pre-‘19 RR and figured since it worked so well on those bikes that it would work as well on the newer bikes. It did ok but was not ideal based on some feedback we received.
We’re trying something new based on the XR bar end weight. We’ll see. Lots of trial and error. We’re not NASA and don’t have access to crazy computer simulators.
Exactly. All changing the mass and cg of the weight does is change the frequency, not actually "dampen" anything. But, sometimes you can move the resonant frequency to where it's less or a problem. I've always wanted to actually make a true damper.
Perhaps heavier may not help but will bring the vibration down to a lower frequency so that’ll be ok with me since I’m always in the higher rpm. 🤷🏻‍♂️
Discussion Starter · #10 ·
Also exactly right. We make no claims to actual damping. We are not absorbing energy, we are changing how it is expressed.
The best ones I've tried including your have been the alpha racing bar end. They aren't perfect but do work.
One would tend to think so (and I would tend to agree), but, since you now have a large mass on one end, resistant to movement, the center of the tube may vibrate more since vibration, like electricity, will take the path of least resistance. You'd really have to either simulate it or test it (accelerometers) to truly know what was going on. I've done some vibe table work over the years, things are a LOT more complicated than they would seem, especially with that many parts in the chain.
That's why a system that truly damped the bars would be best. They tried rubber-mounted bars over the years, but that idea never panned out since then all your steering inputs and front end "feel" were all spongy-feeling, the LAST thing you want on a sportbike.
2021 s1000rr
I'd love to see you develop something for the gilles gp lite bars.
Discussion Starter · #16 ·
Those look like standard hollow clip ons. That would use a universal type bar end. We have those in two sizes depending on the inner diameter of the clip-ons.
I would not recommend the universal type weight for racing or track use.
Discussion Starter · #17 ·
A company called vibranator tried making a tuned mass damping bar end setup. I don't think they're around anymore. I think the product was very expensive, and I don't think it accomplished anything better than by just adding mass. It seemed well made though.
The difference is the last Gen had vibration at lower RPMs and your weights did a great job. This Gen the vibration is higher in the rev range , at 8K rpm is the worst for me.
Yeah, on my '15 my right bar in particular seems to peak at about 4k RPM, which if I remember is right about 50mph. Replacing the OEM giant exhaust can with the Yosh R-55 LE almost completely cured that (see above comment about # of parts in the chain) as a side benefit, but I can still feel that peak. Smooth as glass at 80+mph though. So, if I ever get pulled over for that, I'll simply tell the officer I'm simply trying to avoid a career-ending carpal tunnel injury... 🤣
LOL Sounds like either the new Ahhhnold movie or a new sex toy...or maybe a sex toy named after the movie... 🤣
I've never heard of it, I'll have to look them up and see what their approach was.
1 - 20 of 27 Posts
