1 - 20 of 35 Posts
DO any of our racer and Track Day A-group types have any real world experience with the new Q4s?
I'm wavering between Q4s or GPAs, ive been running GPAs....
Help me decide...
I don't have direct experiance, as I run Dunlop slicks. Mid-pack A rider.
However. I have ridden Q3s before, and know the differences to the Q4. I know A group riders that run Q3s. The Q4s are supposed to be amazing.
I'm good friends with a Dunlop dealer that also runs a trackday org. They can't tout the Q4s enough for track day riders that don't run slicks. They don't reccomend them for street or occasional track, the Q3s are better there.
I've heard in the past that the GPAs are a comparatively heavy tire. I think the only real advantage of the GPA is the flippable rear.
If you are just doing track days, I'd say give the Q4s a shot.
Sent from my SM-G960U using Tapatalk
The big difference I see is that they recommend warmers for the GP-A and they don't for the Q4. I question whether a rider would ever get the GP-A up to temp on the stree, where I think the Q4 would work great. Never used either one, so that's only an opinion based on reading the specs.
I had brand new Q4's for my RR at COTA and just couldn't get my mind around not having slicks for the heat of the day and my pace, so I switched. The tire guy was swearing by the Q4's and said they would be great, but I just couldn't do it.
I ran them with the fella's on the twisties a couple weeks ago and they felt great! Coming from the RS 10's that I swear by in the twisties, I was pleasantly surprised!
For street riding, would you take the Q4 over the Metzler K3 tires? I have been surprised by how good the K3 are for street riding.
I havent used anything but Dunlop Ntecs on the Track in years. I also havent used anything but Q3s and GPAs on the street in years.
The Q3s are excellent street tires, and the GPAs worked just fine in the Cali heat, but the GPAs are a bit squirrely in the colder temps in the am. I wont ride them on the street below 75*. Once warmed up the GPAs were fine for canyon carving.
I think Im gonnna try some Q4s this Monday
I guess that would depend on the conditions you ride in. The q4s have no tread on the side of the tire, I wouldn't want to ride em in the wet.
I don't ride on the street anymore, but when I used to I had Metzlers on my KTM and they were great in the rain. I've also used Q3s as rain tires on the track.
If you are only riding in dry conditions I bet the Q4s would be best.
I am almost through a rear on my first set of Q4s. I only ride to and from the track and on the track. I am liking them more and more. The even wearing on the rear while track riding is particularly nice. Due to the fusion of the dual rubber compounds on the Supercorsa rears, I found that they beveled on the sides very quickly because the hard center just didn't wear down near as much as the sides.
One day when riding on the Q4s it began to rain at the track shortly after we all arrived. I got bored staring at the rain falling on the track after about an hour and decided to try the tire out in the rain. This was not a good idea. It just spins and slides a lot in the rain on a liter bike. I think that it would be a terrible street tire in areas where you will get caught in the rain from time to time (like south Louisiana). I believe that Dunlop would likely tell you the same.
This seems to mostly be a track tire for people like me who don't use tire warmers (I can't fit them and a generator into my backpack.)
Discussion Starter #10
Ill let you know Tuesday my thoughts....going from GPAs with warmers to Q4s without warmers
Does that mean you'll be at the Keigwins T-Hill East TD Monday or Tuesday?
Why not run the warmers with the Q4s also?
Tire is designed in a way as not to need warmers. Why go through the hassle if there is no advantage to it? I wouldn't.
I'd go through the hassle because it's really nice knowing and setting what your hot pressure is prior to getting out on track and not having to spend a lap warming them up.
Unless you just give them just a few minutes on the warmers street tires will overheat and get greasy. Sure you can get them right up to 150 if you want, but I think you'll find that temp to be too hot for DOT's in general, not just Q3s. Yes a little warmer heat for the first session of the day is nice for confidence building, but after that it's not necessary unless you go banzai at the first corner on your outlap. It takes me a lap to warm up the brain, so the tires are ready when I am.
But I think Dunlop would like you to use warmers, you'll be back for another set a lot sooner. Just my experience, maybe 12 sets over the last 2 years.
Ya I guess I see that. It's been awhile since I ran street tires, and riding in the seattle areas where most of the season is cooler I always used warmers. Never had any premature wear, but again it didn't hit triple digits.
I'll be at Thill mon/tues - would be cool to meet some of y'all since I'm new to the area.
I'll be there both days. I'll probably be in my usual spot. The North end of the 2nd canopy. Blue HP4 #439, Red Ford Escape with a Kendon trailer in sight.
screen capture windows
upload picture
Cool! I'll lookout for you. I usually pit along the fence between the two awnings.
Blue and white #905, big ol Seahawks ez-up is easy to spot.
Warmers on low setting on Q3+/Q4 work well. Using high setting will make them greasy. Running 2 laps (no warmers) to warm up tires could work. Warmers get wheels and whole carcass warm and it makes a good difference. Why waste 2 laps of every session? 2x(7 to 8 sessions) that's a whole session wasted.
1 - 20 of 35 Posts
