Finally, they’ve arrived! Puig Windscreens for the S1000RR are at RidersDiscount.com! Available in light smoke and dark smoke, the Z-RaciTo install the windscreen, simply re-use your OEM mounting bolts and expansion grommets.
We have these windscreens ready to go – just call TJ at 866-931-6644 ext 817 and be sure to mention you’re a forum member. You may also email us; FORUM at RIDERSDISCOUNT dot COM with the subject line PUIG S1K where you can tell us what color you’d like your Puig and where to send it.
Light smoke in the foreground, dark smoke behind it.
High-quality fabrication means the finished windscreen has no rough or sharp edges on the outside …
… or the inside.
Dark Smoke.
Light Smoke edit: Puig is no longer including the gasket that lays over the top edge.
… or the inside.
Dark Smoke.
