If it is true, I did the test until 2016 and I assumed that they all had the same distance and now I will see to analyze for which model and adopt it, thanks for the comment.cool! Just a heads up the mirror bolts hole distances from some of the generations don't match.
Thanks for the information, I find it very useful.I had a 2016 and the blockoff plates didn't fit my 2020. I had to buy new ones.
I keep my mirrors on normally and these made me consider removing themI'd buy them...
If I plan to sell them, I only need one model to finish the project, but my problem is that I live in Argentina and here it is expensive and very difficult to carry out an idea ... I am trying to solve that, I also have the idea of being able make the pieces outside of Argentina.They look excellent, are you selling some ?
Sent from my SM-G975F using Tapatalk
I designed it thanks to an idea and also when I saw on a friend's motorcycle that the ones I had bought were poorly designed, and I worried about the good grip, covering the entire hole.I'd buy a set as long as they cover the entire hole the mirrors cover up. My Lightech ones are too small
Thank you for your inquiry, I will tell you that I am just solving that too, the limitations of the company that will do the machining for me, tomorrow I will send you the project and you will analyze it to see if I have to make any modifications to the model. And the letters are correct, I have to resort to the laser, perhaps I extrude the letters less so that the lazer can work well.Nice renderings! Question: How do you plan on getting that deep, sharp, acute angle in the bottom legs of the R? EDM it? It would be easily done with laser marking, but it wouldn't be as deep as shown.
Just curious...
Yeah, I've done CAD (Creo) since '96, and the only way to get that sharp point is by EDM (to whatever depth - very expensive) or to a very shallow depth with a laser (cheap). Plus, anything deep would just get [email protected] building up in it and hard to clean out. Any milling cutter is going to leave a radius, and wouldn't be as sharp or look as nice. So, I'd go with laser.Thank you for your inquiry, I will tell you that I am just solving that too, the limitations of the company that will do the machining for me, tomorrow I will send you the project and you will analyze it to see if I have to make any modifications to the model. And the letters are correct, I have to resort to the laser, perhaps I extrude the letters less so that the lazer can work well.
