21 - 40 of 164 Posts
Discussion Starter #21
on a side note - kind of a request if BMW is watching...on the mobile app...if you have a technical issue that throws a code. Make it so you can pull up the error on your mobile device. Would be fantastic!
MAX BMW are good people...they'll take care of you. Sorry to hear of your misfortune, though...that can tend to put a cloud over things. But it'll get sorted and you'll be back on "Cloud 9".
The twist throttle is based on an adaptation value that is programmed in by ISTA. I have seen in person the drop off and zero response you are referring to. On that K67 the throttle started working again after it was turned off and sat for about 10 minutes. Not sure that just simply turning off and right back on would have worked as it was not tried. Hopefully the dealer will just calibrate the twist throttle and you will not see the problem again. I really dont see how they can do much more than that.
Discussion Starter #25
i gotcha ty for the input.
Yeah i did try to turn it off and on. no dice. Off and sit for 5-10 did work but then the issue came back.
It sounds like a quick fix vs a hardware failure then.
The dealer can reset the twist grip adaptation value. See how it goes from there. If it plays up again, they can replace the twist grip and also check the connector and pins. Otherwise it's a software glitch. But since it is not widespread, I doubt thats the case. Most likely to do with your specific bike. There will be fault codes stored anyway. They should be able to diagnose it quickly.
Discussion Starter #28
dealer should be here in 20-ish minutes to pick up the motorcycle. Hopefully will get some update later today.
What usually is happening in these situations where a glitch occurs is that the hardware is put into a situation that missed testing at the factory. Which means that the problem can be there for every K67 with XXX code version, however it just will not show up for everyone because the same conditions were not met.
first one I was told about was on a racetrack and downshifting with high RPM result, no throttle trying to pick the speed back up.
second one was on the street and hit a rise in the road, slight wheelie, downshift enough to get into upper RPM's, make a corner and pick up the throttle, but no response.
Now yours. Does not sound like you were in any of these situations. The limiter is still in place, I would think you are just mostly riding it hard enough to break it in, but you are limited to 9200 RPM and 123MPH.
The only common thing about these 3 events is that all were updated with the December code release. I am sure BMW is just like Apple. They tell you about 2 or 3 details of the update when it can in fact be updating 50 things. The result is events that occur because something was missed in testing and someone found the issue in the real world.
I have found that adaptations some how change in the ECU under use. The 15/16 code was the worse. I reset my adaptations right before a track day or race and had much better shifting and smoother throttle response. The 17/18/19 ECU was really good. I seldom felt the need to reset the adaptations on it. The 20 is still changing so much in coding it is difficult to tell what is working or hurting it.
Discussion Starter #30
Yeah i was stopped at a redlight when it happened. Before that no issues, then when the light changed from red to green and I gave it throttle I got the check engine light and no power.
Dealer picked the bike up at 9am this morning. Will hopefully hear back soon.
Discussion Starter #31
Dealer update: They found a software update that needed to be performed that the bike was lacking, they believe this update will resolve the issue. Apparently the bike had version K001-19-11-510 and they are installing to the next version *-511?
No hardware failures were found.
@BMW_388 - is this what you were referring to as the Dec update version (511)?
Welp, this is a first as a BMW owner....71 miles in...and below pops up. I lose all throttle input except for 1% can maybe get to 5-8mph. Let go of the throttle and the bike dies. On the phone with MAX BMW NH and setting up a time for them to come get it......went from being on top of the world to in the dumps...... Luckily it happened less than a mile away from my apartment. it really sucks pushing a brand new bike down a busy road home....
Side note what does the circle with the line through it mean? trying to find it in the manual.
I received the same fault when I had less than 50 miles on mine. Thankfully I was already on the way to the dealer to pick something up I had ordered.
The service guy immediately hooked it up to their diagnostics, said something about a fuel pump alert, and cleared it. The dealer contacted BMW who they said it had been seen before in some brand new bikes - I forgot the technical explanation - but it doesn't tend to return. He told me that they would replace the fuel pump if the problem reoccurred. It never did, and I forgot about it till seeing this post since it was such a nothing event.
Hope the update does the trick. And you should tell them to take it out or a long test right before giving it back to you because that would totally suck if it happened again.
Do yourself a favor and siphon some fuel from the deepest part of your tank and take a look at it. I documented my issues with my bike dying on me and the fuel pump issue in this forum. I was the only case at that time. Ultimately, I believe that when I got the bike it had bad fuel in it, as I did not have the problem with my other bike which I fueled at all the same locations. The fuel that came out of my bike from the deepest part of the tank looked shitty,
Fuel comes in a few different colors depending where it comes from and what additives are put in it. Did I read the manual correct, max 5% ethanol??????
Discussion Starter #36
10% max i believe is what i read. Fuel shouldnt be an issue but ill take a look when i get her back.
Discussion Starter #38
Oh youre right - i was reading the alternative fuel quality.... isnt the ethanol standard at most pumps 10%?
Discussion Starter #40
ive never noticed this in all my years of riding. guess i need to find a local gas station that has ethanol free or e5
