Ohlins Steering Damper for the S1000RR (10-11)
The basic functionality of the Öhlins® steering damper is that the piston, which is fixed on the shaft, pushes oil through a separate parallel passage in the housing. An adjustable valve in this passage gives an 18-click broad adjustment range. The settings are made with an adjustment wheel, located on the end of the steering damper cylinder. PTFE-coated seals are used in the dampers to achieve the lowest friction level possible. Öhlins® advanced suspension technology is the industry leader in terms of high performance and superior quality. Öhlins® stabilizers are used by top racing teams around the world.
CLICK HERE TO LEARN MORE
