Need the panel under the windscreen and need the right rear panel behind the seat in Hockinhem silver
This is correct. I use Ultra Black RTV to make some rubber pads for it and it does not rattle that way any more. It was wearing out the push pins and made so much noise at 45MPH.mine is a 2020 and I believe has the rectangular pins
Nope, mine is very factory complete. If you read enough on this forum ,there are many complaints on the rattle. Bad design that required a redesign for the late 21 into now 23..The rattle problem is exactly why I took it off, if it will still do it with new one then I’ll just leave it off permanently but mine had the front hook piece broken so I figured that was the cause of the vibration noise
Sorry, not sure I understand, when you say panel under the windshield are you referring to:Need the panel under the windscreen and need the right rear panel behind the seat in Hockinhem silver
