That kinda sucks. Anotger reason i like my forged wheels. $645 out the door for a set of michelin power cup 2 with balance beads not ugly stick on weights.
Oil change... do it yourself man. Parts are about 90 bucks. Takes all of 10 min.
How often do you do yours? I'm doing mine every 3k.
I do my own oil time to time, just have to do the dealer BS to make sure if that there is an issue that BMW can’t use that as a way to skip out on the warranty. My oil changes where at 500 miles then again at 3k and now at 6,500. So around the 3k-4k I change the oil. However it can last for far longer. When I hit about 25k miles I change the oil at 6k-8k miles. Usually the motor is broken in by that time.
Never had an engine burn oil before. So I think I’m doing it right.
Always have used 10w-40 Castrol fully synthetic in both my RR’s had 30k miles on the last one and never required any shims on the valve lashing. When they pulled the motor apart after I got hit. Dealer said they had never seen a motor so clean with no signs of abuse or ware.
because the engine ran on the side until it turned off the stater and the clutch or completely welded together. Unfortunate
Dealers labor rates have got out of control. None of the technicians have gotten raises. Something going to give.
i’ll probably get another set of wheels for the bike. but I like the carbon wheels a lot.
