Morning all, I was not sure where to post this. What stand do you use to work on bike? I am not talking about lifts. I have a limited amount of space and would like to be able to move it around. Thanks
True but when more is needed. Two Pitbulls/Dynoamoto, etc. for front and back start to approach the cost of a Bursig. Add the Pitbull front fork lift option (do others offer this?) and the difference is even less but still cannot be wheeled around. Then add jack/footpeg stands to work on the rear and the cost is higher than a Bursig.Pitbull stands are all MOST people really need. You can do most maintenance/modifications with a front and rear stand. The Bursig as mentioned above is great, but like the Abba, is not cheap, but you can completely disassemble a motorcycle with it. If you want to be able to rolling around a little, the Dynamoto stands are really nice.
A pitbull front and rear can be had for less than $400 on the used market. The only thing I dislike about the Bursig is sometimes it can be finnicky to set-up and only rolls around well on super smooth surfaces. Like somebody mentioned above, it gets wobbly and that's a bit too sketchy and nerve-wrecking for me.True but when more is needed. Two Pitbulls/Dynoamoto, etc. for front and back start to approach the cost of a Bursig. Add the Pitbull front fork lift option (do others offer this?) and the difference is even less but still cannot be wheeled around. Then add jack/footpeg stands to work on the rear and the cost is higher than a Bursig.
