1 - 10 of 10 Posts
Hi. I bought one of these off the net to mount in my factory BMW Navigation Mount. However. When I fit this into the cradle and it locks into place and then plug the charging cable up to my iPhone it will not charge. Am I doing something wrong. I have a 2016 S1000XR and it has the factory Garmin navigation mount.
Can you try using an actual Apple cable instead to see if it’s the cable or not is the issue?
2021 S1000RR M Sport
Does that ebay cradle replace the OEM cradle and wire into the same plug that OEM cradle plugs into? Or can you plug it in over the top of the current cradle like having 2 cradles? I would be confirming that the OEM cradle works with a NAV on its own. Then if the ebay cradle is not picking up the power it must be faulty.
Discussion Starter · #6 ·
If I had a Garmin Nav I’d plug it in and check but unfortunately I do not. All I have is the factory nav mount.
Discussion Starter · #8 ·
To close this out. The cradle is bad. The seller won’t make good. I’m out $27 so whatever but just wanted to pass it along.
1 - 10 of 10 Posts
