21 - 27 of 27 Posts
Here's the Maintenance schedule from the Repair manual
Here's the Maintenance schedule from the Repair manual. The format is a pain to read, but it tells you all you need to know...
(+) Reading fault memory with BMW Motorrad diagnostic system
=> Oil change in engine with filter (for maintenance) (Description in
item: 11 00 609, Billed as a separate item) Annually or every 10,000
km
=> Checking valve clearance (for maintenance) (Description in item:
11 34 502, Billed as a separate item) every 30,000 km
=> Checking valve timing (cylinder head cover removed) (Description
in item: 11 30 502, Billed as a separate item) every 30,000 km
=> Replace all spark plugs (as part of maintenance) (Description in
item: 12 12 509, Billed as a separate item) every 30,000 km
=> Replace air filter cartridge (for maintenance) (Description in item:
13 72 505, Billed as a separate item) every 10,000 km
=> Changing fluid in telescopic forks (for maintenance) (Description in
item: 31 42 902, Billed as a separate item) every 30,000 km
(+) Visually inspect the brake pipes, brake hoses and connections
(+) Checking front brake pads and brake discs for wear
=> Changing brake fluid, front brakes (Description in item: 34 00 548,
Billed as a separate item) initially after one year, then every two years
(+) Checking brake-fluid level, front brakes
(+) Checking rear brake pads and brake disc for wear
=> Changing brake fluid, rear brakes (Description in item: 34 00 549,
(+) Checking brake-fluid level, rear brakes
(+) Check the steering-head bearing
(+) Checking coolant level
(+) Check the play of throttle cable
(+) Checking fastener of clutch lever fitting
(+) Checking clutch cable and clutch-lever play
(+) Lubricating clutch mechanism
(+) Checking drive chain, sprocket and pinion
(+) Checking tyre pressures and tread depth
(+) Checking ease of movement of side stand
(+) Lubricating side stand
(+) Check the lights and signalling equipment
(+) Function test, engine start suppression
(+) Final inspection and check of roadworthiness
(+) Setting service-due date and service countdown distance
(+) Checking battery charge state
(+) Confirming BMW Service in on-board documentation
just IMHO that 30,000km is way too long, even after 1 year or 10,000km the fork oil is a horrible grey sludge...
I recognize I'm reviving an old thread, but it might be worth adding to it since this is the first post that pops up for S1000RR service interval with google.
http://www.ascycles.com/bmw_motorcycle_service_and_maintenance_schedules.aspx#S
There is a nice checklist we can print to help with servicing and record keeping. I'm sure this is posted in other parts of this forum, but worth sharing again.
Basically, service on these things are due every 6k miles. Some of us may elect to change the oil every 3k. Schedule posted earlier in this thread is incorrect because service shouldn't go from 6,000 to 18,000. I read the A&S schedule as basic fluid and filter every 6k and same plus valve every 12k.
21 - 27 of 27 Posts
