My thoughts exactly. The rr from what I’m seeing is definitely better for a big majority of people power wise. Of course this is just from what I’m seeing from the graph. Should be interesting to see what it does with the flash. Obviously the m is for the track as we all knowI'll take the green curve all day long and twice on Sundays....but then I'm a street rider. Makes you wonder if the S actually accelerates faster since it makes more power LONGER (area under the curve) than the M (I'll bet it does), with the M ONLY having a slight advantage at the very top and more over-rev. So, yeah, a slightly better race motor IF you can keep it at the peak.
Thank you for your videos, very interesting!Hi guys. I made that video. We had trouble getting the bike to stick on the rollers. As stated in the video, we had to let air out the tyre to help it stick. The plan now is to get it dynoed with a flash. Both bikes has the same sprocket gearing, but the M has a heavier 525 chain. Alot of variables. Theres no question that the "regular" S1000RR is powerful as hell, but we believe that a proper tune and a more broken in M will produce more power.
