It's not just gearing, it's the expensive, lighter internals (again very similar to the CBR and ZX-10RR)The M revs quicker most likely from different gearing.
- RR four-cylinder engine developed for racing purposes on the basis of the RR engine. Even more top performance, higher torque in the mid-range and 500 rpm more maximum speed.
- Output 156 kW at 14 500 rpm, 4 kW more than in the RR. Maximum torque of 113 Nm at 11000 rpm.
- New 2-ring forged pistons, each 12 g lighter, adapted combustion chamber and increased compression to 13.5. In addition narrower and lighter finger followers.
- Fully machined intake ports with new port geometry and BMW ShiftCam technology for varying valve timing and valve lift.
- Titanium valves, with new spring assembly on the exhaust side, narrower and 6% lighter cam followers and optimized camshafts.
- Very light, compact basic engine with longer and 85 g lighter titanium connecting rods from Pankl for reduced friction and lower weight.
