You guys must not buy brand new S1000RR at least since 2019.
There is a form you are required to sign that clearly states in Kilometers that you will break in the bike to 1000KM.. that happens to equal in US 621.371 there about. I have the form from my 2020 I got June of 2019, and I have the form on my M1000RR I got July 2021. You are 100% responsible to make that mileage number and not tamper with the reset. I will see if I can find the form from my M1000RR since I think I still have that paper work all together. If you dont have this form, I can only guess that some dealers dont care about this form and make you sign it.
The cluster has the service miles programmed in it at the factory. That number I have seen in the cluster is typically 624 miles. There is no date limit to the break in, so if you happen to buy the bike and it sits 2 years, it still going to require the distance of 624 miles there about.
As to the break in process of an ENGINE.. it does not matter if you call it a daily driver engine, or a race engine. How many variation do you want to read about or watch a video ... Just google it ..
Break in of an engine has been taught and pass down from master mechanic to student for as long as the engine has existed. Very few will use my process and I have this process based on building 100% race engines where clean clean clean cannot be over used in making sure a $50,000 race motor will live.
I change the break in oil and filter at 500 miles. ( I have my K46 2015 oil filter still on the shelf along with my K67 and K66 oil filters ) .... put in the oil I intend to run and go to the 624 miles mark. I let the dealer change the oil and filter again. Then at 1500 miles I change the oil and filter again. I am finally happy to left the intervals be 2000-3000 miles depending on how many track days are involved.
There is no real set time on changing oil. Look at the old days of drag racing when those guys ran 1/4 mile and changed the oil and filter EVERY run down the 1/4 mile. Alot of reasons for this. Fuel saturation, heat in the oil causes break down even in 1320 feet, check the oil for bearing material or camshaft bearing material to catch a failing bearing after every run.
You do what is right for you. Its your time and your money.
BMW Motorrad says you can buy a BMW S1000RR and ride it 1000KM and they will change the oil and filter at first service. Then they will reset the cluster to 1 year or 6214 miles which happens to be 10,000KM.. I do not agree with 6214 miles what so ever. I would never go beyond 3000 miles under just normal commute riding.. but again, that is just me and my process.
