1 - 2 of 2 Posts
'21 S1kRR
Not sure what I did wrong here. Removed the front wheel on my K67 to change the tire. Removed ABS sensor and both calipers. Reinstall wheel. Went for a test run and brake pressure would build by cycling lever but then drop to zero. Weird.
Bled lines and everything is back to normal. Maybe I had a bubble in the line that dislodged when calipers were moved around? Thoughts?
Sometimes that is what happens. Bubbles stick to the side of lines and release as you move them around, or even just ride.
Reactions: Amok and JFlo
1 - 2 of 2 Posts
