Not 100% sure if this is the right section, but if not feel free to move admin. So after doing hours of searching I still haven't found out my complete answer
I have a 2012 RR and I usually run Q3's 190 55 17. Changed the tire on Friday and went with a Pirelli Angel GT same dimension as the Q3. I lead with this bc this is the only thing that I changed.
Rode it for about 2 hours yesterday and about halfway through my ride I felt power shut off and the TC light flashed for about 5 seconds, turned off and power came back on. Then my buddy rode it for about 5 mins and the light flashed again and power dropped. He pulled in the clutch and the motor died. I turned the key and the gauges swept, but nothing happened when I hit the starter. I waited 10 mins and did some research and found a ton about tire size diameters and TC. I then tried it again and it started, so I immediately shut off TC and tried to ride it again. Shut down after 1 min of riding and now wont start again. When you turn the key on the TC light is solid. Tried disconnecting the battery and nada... I called the local BMW dealer and he suggested a bad starter switch!! I told him a bad starter switch wouldn't make TC flash and cut power, and the bike was running when it died.
Thanks in advance
Thanks in advance
