Good day gents,
I am posting this thread seeking your precessional thoughts and opinions.
I am planning on upgrading my halogen light bulbs with LED bulbs in my ‘17 s1krr. There is so many options out there and I am not sure what to choose from at first. Eventually I decided to go with Philips bulbs (unless someone knows a better brand name that I missed) I want to stick with the OEM look as much as I could. Most of the ones I found were with relays and my concern here is, do I really need a relay (adapter/LED ballast) to install them and have them function properly the way I want? What I am aiming for is to eliminate the flick of the low beam when flashing with the high beam. Do I need a relay to eliminate this issue, or it just really depends on the quality of the bulb itself? Or the harness setup of the bike? If I don’t need the adapter then it’s just a matter of right choice with extended headlight rear cover to cover the bulb instead of having the bulb exposed to water and stuff
let’s say I ended up having to get the ones with adapters, can I install the adapters if they’re thin enough inside the headlight hidden somewhere?
Any help would be very appreciated guys
many thanks
many thanks
