This is great! Curious to see Xworks Vs Euro.
Since I just got this code loaded last Wednesday in an ECU, tested it enough to say it works, it needed to go to the dyno testing so I did not get to datalog that ECU yet. it is on a K67 that does not have a 2D datalogger setup by me so it will read the PID and SID parameters.So what in the tuning makes the HP loss in the upper RPM ranges?
nice data. thanks again for getting my '10 running again so quickly and support getting the other gremlins worked out of it. hopefully i can get it broke in soon and get it back up there for dyno!I had the opportunity to work with a customer wanting to test the new 2020 K67 Stock ECU vs the Torque Optimization ECU ISTA coding RetroFit in the last few days.
The Stock ECU was sent to me to clone up a stock ECU and then apply the dealer ISTA retrofit of Torque Optimization as it is called in the RetroFit section.
Customer has a 900 miles March release and wanted to keep the stock ECU stock. Then get an Torque Optimized ECU for Dyno testing. Simple enough for me.
The dyno was a DynoJet 250i and the operator indicates that in real world HP numbers it is about 3-4HP soft on the big end. This comparison of numbers was based on using bone stock K67 to establish base line taking the 205HP claimed crank HP and coming up with 6% driveline lost @ 192.7 HP at the rear tire stock K67.
So with that in mind we are supposed to maintain this is testing on the same dyno same bike same day within even 2-4 hours of time.
Just a little preview for next week, there will be 4 ECU's in this test > STOCK vs OPTIMIZATION vs EURO vs XWORKS < I am waiting on my shipment from Germany for 2 more ECU's so that additional ECUs can be loaded to the same bike on the same dyno at the same time frame. No one else has ever even done it for 2 ECU's let alone 4 working on the same bike.
Can't be helped. It's an emissions issue.This BMW flash did NOT fix the coldstart issue.
Page 254, yes it says 2022 but the pictures and instructions are for the MY2023<snip>
So lets take BMW numbers you have posted for what you call the 2023, but, I have not see this Owners Manual yet, so please post the link to the PDF on this 2023 S1000RR owners manual.
<snip>
I am pretty sure my dyno results speak for themselves.@BMW_388 did you ever ger around to comparing the EURO ECU? Were to graphs much different to the US ECUs?
