Is it just me, or do these spools not look right? There's a bit of a gap between the actual bike and where the spool starts.
I contacted the store and they said it's normal. The part number was right PRN012561.
They look like they're sticking out way too far and not flush.
They are just machined that way. Is it fit and function? Yes, they fit on the swing arm without binding against the swing arm recess. Do they function as lift points for the rear stand? Yes, they do as you will just adjust your rear stand to the spools ( as long as yours is adjustable ) ..
Do they look right? No, they are sticking out too far in my opinion.
I have some $25 spools that are flush up against the swing arm and allow for the exact amount of recess area in the swingarm so they do not stick out in appearance. They are just the extension of the swingarm so the PitBull stand attaches and does its job of lifting. I have 7 S1000RR and it is a 100% requirement that my pitbull stands will interchange from each bike to bike so I dont have to remember which one goes where.
You can modify those spools if you have a belt sander. They just need the part going against the swingarm recess ground down so they fit more flush. There is still the other step point they built into the spool that is going to stick out too, but at least they would be tucked in better.
