1 - 14 of 14 Posts
At about 18:00 seconds in the attached video you can see that the sports display on the dash changes from the Sports 2 display back to the Sports 1 display.
I was using the Sports 2 (or 3) display to show the lap time and the delta compared to the best lap. This is working fine.
My issue is that I am unintentionally changing the display via the Multi-Controller.
Question: Is it possible to select the Sports display and have it stay there? or make it the default display?
Or is the better option to replace the Multi-Controller with buttons?
Helmet Tire Wheel Sports equipment Vehicle
It is possible for me to make your Sports Screen the only screen. You will not have the intro screen 1 default.
However you are not in the USA so shipping your hardware would be needed to the USA.
Reactions: goffred
you accidently hit the wheel the most when on track and you want to adjust the DTC level. The thumb actuation of the rocker switch + - can cause you to move the rotory wheel sideways and causing the screen to change. that is super annoying on track.
Reactions: Littlebitoquickness
2021 s1000rr
Anyone have the Alpha button pod? I'm so frustrated with bumping that wheel I'm considering it. Asafp.
I bump the wheel all the time. My newer Heroic gloves have a bit more stuff on the back of the thumb than I am used to.
Discussion Starter · #10 ·
I hit the wheel all the time and know before I even watch my videos
Yes, I also know before I watch the video :)
Sometimes I even change the screen back when I get a chance. This is a tight little track though and my ability is not great, so concentrating on the track is usually a better use of my brain. Especially as I have generally unintentionally changed the screen again within a lap or two.
I have even tried just mechanically chocking the gap in-between the controller and the switch housing after selecting the correct screen. The controller doesn't move much then, but just a fraction of an inch is enough for the switch to work. It's really sensitive. Which is normally a good thing?
Your video is great! What camera are you using and how are you getting the displays on the bottom?
All and any tips appreciated.
Discussion Starter · #14 ·
Shame about the sound (hey Frank), I haven't worked that part out yet.
It's a bit of stuffing about.
Video is using GoPro (9 I think? Newish anyway)
The telemetry comes from the BMW data logger. You can export a .CSV file.
The GPS from the GoPro itself.
I use race renderer 3 software by HPtuners which is common for cars and bikes for track/race for videos. You can add all sorts of dials, etc.
Synchronise both files for time (I used the gear changes into 4th gear)
Race renderer creates the final video.
I'd rather have the info on the dash live than the video (the video stuff is just a secondary thing), which is what the original post is about. The live Delta works great. Until I unintentionally change the dash!
1 - 14 of 14 Posts
