Do you know how the DDS front fork handles compression / rebound settings without the 2D sensor / separate settings? Is the rebound setting set to the same setting as the compression?I fixed my post. That is more correct that the 150 and 175 are front options. I use the 175 as I noted in my corrected post.
And I have my sensor mounted where I have 100% steering left and right... 8000 miles and zero failure.
2020 2D Racing Front Sensor Install - Working / Not...
So I thought it might be best to do a thread on this 2D sensor install because this is the unofficial carry over install from the K46. It failed, and it worked. Do I recommend others to try this? No, not really unless you are very handy with drilling and tapping holes in a very nice new front...www.s1000rrforum.com
