I wanted to make a DIY for everyone who is considering doing this, as I had a lot of questions myself, before I started this. Let me start off by saying this is quite a bit simpler then I had expected, with the exception of the steering stops giving me a tough time.
Let’s get started.
I used the alpha mounting kit that installs over the front wheel speed sensor and a hollow bolt for the lower part of the triple tree.
I also used the alpha racing steering stops, which restrict the steering angle by a bit more then I would like, but they’re very nice and look oem, as most alpha parts.
1. Remove both side panels to gain easier access to the frame near the forks.
2. Remove one of the two radiator mounts entirely and loosen the other.
3. Install steering stop on one side with new supplied bolt, do not fully tighten, yet.
4. Install other side and tighten to spec
-The result should look something like this
It's fairly easy to figure out which side goes where but the passenger side has a slot for the clutch cable, easiest way to tell.
5. Remove the upper bolt of the lower triple tree and swap it with the supplied hollow bolt, tighten to spec.
6. Remove the bolt for the front wheel speed sensor, place the bracket over the sensor and use new bolt to reinstall it
7. Install the mounting balls into the hollow bolt and the upper bolt of the lower bracket, using a 5mm open wrench and be careful not to over tighten them. I decided on this purely because I saw it done this way on Alpha's website.
8. Instal the 2D sensor
9. This may be optional, however I was uncomfortable with how close the sensor got to the inner plastic and trimmed. It appeared as it may clear without doing so but just a little bit of trimming really gave the sensor some breathing room. I used a dremel to not take off more the needed. Also, the pice in question does not have to be fully removed, I was able to remove the 2 left bolts under the nose and simply hold the plastic back and remove a bit of material.
10. Route the wire in a way that it does not bind or get pinched and then connect it to the unused plug by the EVAP/charcoal canister.
Let’s get started.
