1 - 5 of 5 Posts
Any one use the HP bleed valves there are two different part # 77028543065 or 77028536257. one looks like it replaces bleed valve and the other goes between Caliper and brake line. which one for 14 hp4?
The reason there is 2 types is based on which calipers you have.
The gold calipers used on the base S1KRR has the bleeder in the bolt that holds the brake line on the caliper. So, you can use a bleeder that attaches that way. The HP4 has a bleeder in the caliper and a bolt that holds the brake line on the caliper. So the correct bleeder for it is 77 02 8 536 257
The Base S1KRR with the gold calipers would use this 77 02 8 543 065
thanks i was thinking about getting a set for a HP4
1 - 5 of 5 Posts
