What hearing are you all using? I'm a track rider and want more performance, but I can't seem to find the BMW racing teams specs anywhere
Gear Ratios are suited to the TRACK you are riding on.
Performance in gearing is only based on the change of the feel torque is delivered to the rear wheel. You go from a 3.00 to a 4.00 the feel will change alot coming off the corners. However, you give up top end speed alot.
So, you select your gearing based on the longest straight first. Lets take COTA for example in TEXAS. With the track being 3.4 miles long, and the longest straight between turn 11 and 12, you need to make 196MPH down that straight way to even come close to a good lap time there. Stock gearing will just barely get you there coming off 11 with a very good drive. stock gearing is 17/45 or 2.64 ratio
Now lets take Cresson TEXAS. 1.7 mile track. Longest straight is about 140MPH. Corner to corner drive is very critical there. So gearing going to a "lower' gear ratio makes using gears 1-5 better. Like there I run 15/45 or 3.00 ratio
Now to complicate some things about target use of gearing, I avoid 1st gear if all possible. So, I change the gearing to even 3.13 or 15/47. So why avoid 1st gear? The dreaded neutral you are trying to avoid. I had a GSXR that just refused to shift right from 2nd to 1st. So in order to avoid 1st, I just set the gearing so I used 2nd-6th gears. Never had an issue that way with hitting neutral.
There is no gearing number that fits all tracks, and then works great in all circumstances on the street. If you want to wheelie alot with ease and still make 176MPH top end, 15/45 works great. it is what I use on the street and Cresson racetrack.
