1 - 6 of 6 Posts
The Brembo M4 brake calipers are better than the stock calipers, and are much more expensive. They have 34mm pistons and have a lot of stopping power. The fittings are not the same as the factory brake lines, so in order to run these I had made custom Spiegler lines created, as I did.
Given the size and power of the calipers, I elected to use Performance Friction carbon race pads. I have used harsher pads in the past that have offered less feel and tend to damage/warp rotors. Once you go to a more powerful caliper, the carbon pads can be very nice to use even though they might be overall a softer feel than the sintered pads.
The Brembo M4 calipers are $800 new, brake lines were about $240, Performance Friction ceramic pads were $100 new.
MY PRICES:
M4 calipers - $399 shipped by USPS Priority
Pro-Bolt Titanium caliper bolts pre-drilled for safety wire. I plan on keeping these but if you want these I will sell them for $50
Spiegler blue custom brake lines with gold fittings and distribution block under the head of the frame, made for Brembo master cylinder and Brembo M4s - $100
how much for the M4's by themselves? I assume they're 100mm spacing, so they work on all years s1000rr...
Yes the M4s are 100mm spacing and therefore will work on any S1000rr years.
I have an inquiry from last night, from a local buyer on the Brembo master cylinder. So selling the calipers separately should be fine. I think they should probably sell with the custom Spiegler brake lines back to the ABS pump unless the buyer wants to use them without ABS...
Brembo master cylinder, lever and resevoir are sold.
everything else is still available
Do you still have the M4's?
Yes I still have the M4s, but I mounted them on my 2014 S1000rr so likely will keep them.
1 - 6 of 6 Posts
