I'm using the front end and forks from a S1000R to use on a dragbike i'm building and not sure if they will work.
So- i stripped the ddc unit and i didn't need to. I've refilled it with oil no idea if it should be full or how much to put in there or what grade, does anyone know?
Also, i don't want to use the DDC unit, if there is no power going to it does it not work at all or is it set at maximum damping? Is it possible to replace the internals of the DDC leg with those from another model? The forks don't really need to work as normal, they have been shortened to 50mm travel for a 400kg dragbike.
Any info would be appreciated.
