1 - 6 of 6 Posts
Both my High and Low beams do not work. Voltage on low beam is 8.5V and 0 on high beem.
Checked fuses in the rear seat and all OK. Any suggestions whats wrong or what to check?
You testing with the bike running? (correct answer yes). What is the charging voltage with the bike running ....14.2vdc.
What is the battery reading when you hit the starter. Should be more than 9.5 while starter cranking.
1 - 6 of 6 Posts
