Hi to everyone!
I am having an issue with the DDC on my bmw s1000rr 2016.
Last Saturday while I was riding I started seeing on intermittent basis the yellow light error symbol on the dash and the code “DDC!” displayed.
Does this happen to anyone before?
So far, when I can say is that:
-Same it is showed on flashing/intermittent basis and independently of the speed (at low or high speed seems the same)
-I have done the CALIB of the DDC without errors (I started that bike, leave it on side stand, selected the option “CALIB” is then it showed “DONE”
-I take out two led lights (no can bus) I have previously installed as a running lights, in order to avoid any possible CAN BUS error. Then I select the option “LAMP WARNING OFF” so I did not see the light error for this anymore
-I have disconnected the (+) of the battery for 30 minutes in order to reset the ECU.
As a guidance, pls find a quick video I have made with the bike at home.
You will see the error I mentioned on second 5, 6, 18, 24, 26.
Any toughts?
Thanks in advance for your help and collaboration!
Any toughts?
