Slaki asked: Correct me if I am wrong. I am not riding hard enough for the traction to kick in right? Only turn 2 and 5 it kicks in right?
No and yes.
No part:
The problem is that you have a regular/repeating error in your driving line and/or throttle control.
Turning in just a bit too early, and/or opening throttle 0-30% too early (while in max lean angle).
So, if you now start riding (trying) harder, AND you have that regular error -> that is the most common combination for a hi-sider among fast/race riders.
And, 2 and 5 are the slowest corners of the track, right?
You can not compaire slow/medium/fast corners 1:1:1, because you have different torque (different gear and RPM) available at rear tyre.
And also you have different settings in DTC for slow/medium/fast corners.
Yes part:
You are riding close to tyre traction limit, very close to limit in slow corners.
Also, if you have notised, most of the hi-siders for any (fast) rider occurs in a slow corner (and collar bone snaps).
That's because typically a rider is much more cautious in medium and fast turns.
So yes, you could "ride harder" in medium/fast turns.
BUT, then you would hi-side from a greater speed, 2X...4X higher energy, multiple broken bones etc and season is over.
Additional part:
So my advise is that first fix your line and throttle control, and then ride harder.
The difference is;
If you do not fix the errors, you will hi-side very soon, you will not be faster, you just try harder.
But if you fix those, you will be faster, and then you will hi-side. So at least you get some very good results before hi-siding.
If you f-up line before (late) apex, you can not fix that with throttle after apex, because your line after apex does not allow that.
Causation is the real enemy.
If you still try to fix it with throttle, you will hi-side.
Turn in just a bit later/calmly/smoother, and you can pick the bike up earlier.
And because of that you can open the throttle (keep it linear!) faster and harder.
That is what you want, to open the throttle faster and harder, right?
If your line before apex is correct then also the line after apex is correct, and that allows you to use throttle.
https://www.s1000rrforum.com/forum/...gger-instruction-resources-8.html#post2309734
https://www.s1000rrforum.com/forum/...gger-instruction-resources-7.html#post2289436
General blah blah slogans or something:
Do not try to be faster, you will crash.
Try to be better, and the speed will follow/ and you will be faster.
And a pic, causation between touching throttle too early, and line going wide/ not able to pick up the bike:
http://racedac.com/s1000rr/TouchingThrottleEarlyDoesNotMakeYouFast.png
